In risposta al messaggio di fabgar del 19/02/2018 alle 23:59:57
Ciao, ho la truma c6000 in blocco... i lampeggi della luce rossa dell’errore sono : breve, breve, lungo, breve, lungo, lungo, lungo e breve... qualcuno sa a che problema corrisponde? grazie
L'ho solo in inglese, il codice e' il 46.
Renzo.
46 s,s,l,s,l,l,l,s Error:
1) Control panel Combi or power selector switch Combi E defective
2) Combustion air motor or circulating air motor defective
3) Battery earth to the minus terminal Combi defective
Error information
1) Control panel or control panel cable defective
- Power selector switch Combi E or control panel connection cable defective
2) Combustion air motor defective
- Cable harness defective
- Electronics defective (paint spray in control panel socket)
- Internal connection between the (+) carbon brushes and/or circulating air motor and circulating air motor casing via carbon dust
3) Earth connection from the power supply is missing
1st action
1) Replace Combi control panel /or cable
- Replace power selector switch Combi E and or control unit connecting cable
2) Replace circulating air motor
3) Check earth connection (ground cable) of power supply
2nd action
- Check supply line of combustion air motor - black cable for short circuit to ground or red cable for interruption
- Replace cable harness
- (If cable harness not damaged, replace combustion air motor)
3rd action
Check electronic PCB for paint spray in control panel socket (replace electronic PCB)
𝓡𝓮𝓷𝔃𝓸
